'95-97 Grille Removal and Headlight Installation (Sealed Beam)
Yes, they are low-power high beams, but there is still a wire that goes to the DRL relay, which controls the operation of the DRLs. The wiring diagram pretty much explained how that worked (except that it was wrong in the sense that on my year truck, the DRL control and fog lamps run from the same fuse).
And you're right about the voltmeter. It's something I really need to get right away.
Black strip? What kind of black strip?
There might be a black line/stripe on the ground wires...
See what your headlights do when only one is connected at a time... it might help ya figure out where the trouble spots are...
Well, I pulled off the grille again yesterday, and it turned out the two wires controlling the high beams on the driver's side had popped out of the heat shrink connector. All the other wires on both sides were still secure. It seems those two wires didn't like the heat shrink, soI spliced them into clip connectors. Now my H4s work perfectly -- lows AND highs.
The only weird thing is that the DRLs no longer work, even when the fuse is in (and it's not blown). SinceI hate 'em anyway,I'm not complaining.
ORIGINAL: drperry
Nice!
Time for some night shots! lol.
How's the light output? Do they have a wicked cut-off?
Nice!
