95 blazer getting no fire to coil pack
Old Jan 21, 2019 | 11:29 PM
Flcountrygirl8248's Avatar
Flcountrygirl8248 is on a distinguished road
Default 95 blazer getting no fire to coil pack
I just replaced my coil pack and distributor cap and rotor button on my 95 blazer 4.3 L.
it will turn over and is getting fuel but getting no spark to the coil pack could it be the wire that runs from the coil pack to the distributor cap ?? Please somebody help me i been with out a truck now for 6 months . had to replace all the fuel system fuel lines brake lines. Was bought from someone who was from up north and was in snow and salt. Im in florida .
Old Jan 22, 2019 | 07:55 AM
rriddle3's Avatar
* Moved to '2nd Gen Tech' *
Old Jan 24, 2019 | 09:54 AM
go chevy's Avatar
I would put new spark plugs and wires on it for sure if you haven't done it already?
Old Feb 4, 2019 | 01:18 AM
GeorgeLG's Avatar
Your ignition system consists of a 12v control section where the engine computer takes sensor inputs and tells the ignition module when to initiate a spark. The ignition module the tells the coil with a 12v signal to initiate the spark. The coil then outputs a very high voltage level that is capable of jumping the distributor gap and in turn the spark plug gap. You need to determine if the problem is in the high voltage section from the coil to the plugs or the low voltage section from the sensors to the coil.
the correct way to test high voltage is to form a 1” gap to ground and crank the truck over to check for 1” of strong blue spark. You start with a plug wire pulled from a plug. If no spark then pull the high voltage lead going into the distr from the coil and repeat the test. If no spark then your problem is a faulty coil or in the low voltage control section between the sensors and the coil low voltage/primary circuit. Report back on the high voltage/secondary tests and we can go from there.
Proper diagnosis is preferred over blindly swapping parts as I have suggested here but if you prefer to swap parts, then replace these one at a time:
ICM
crank position sensor
George
lmkokesch@sasktel.net
Apr 19, 2014 07:41 PM
monette999
Sep 12, 2013 11:18 AM
capt nemo
Feb 20, 2012 09:02 AM
pizza123415
Aug 15, 2010 05:08 PM
1995posjimmy
Dec 14, 2009 12:46 AM
