95 Blazer - no evap vent solenoid
Old Sep 2, 2009 | 04:15 PM
louie424's Avatar
louie424 is on a distinguished road
Default 95 Blazer - no evap vent solenoid
My 1995 S10 Blazer 4x4 does not have a evap vent solenoid mounted above the spare tire like is talked about in many threads on this site. There are three hoses coming out of the evap cannister. One goes to the tank rollover valves, one goes to the engine, and the other is routed up into the fuel filler door area. Can someone tell me if the valve is missing, or if the lines are routed correctly? I'm getting the evap system check engine codes, and was trying to find this valve.
Old Oct 17, 2021 | 10:23 AM
hunter04's Avatar
hunter04 is on a distinguished road
Did u find and answer to this? I have the same issue. I know you'd is old but I still run my blazer to the mountains.
Old Oct 17, 2021 | 12:44 PM
GeorgeLG's Avatar
I have never worked an a '95 but the wiring diagram shows no vent solenoid and neither does Rock Auto so I suspect that the design does not use one. There must be a check valve up at the fuel door to allow vacuum testing of the system. What codes are you getting?
George
Old Oct 17, 2021 | 01:51 PM
GeorgeLG's Avatar
Here is a vacuum hose diagram for a '95 which also shows no vent solenoid:
George
wetbar
16
Mar 14, 2021 10:13 PM
HamToast
15
Jan 16, 2014 02:22 PM
hilsenteger
Mar 22, 2010 09:18 AM
red4x4
24
Mar 12, 2010 07:41 AM
95redblazer
Jul 9, 2009 12:28 PM
