95 blazer possible timing problems?? need help please
Old May 24, 2011 | 02:54 PM
silver bullet80's Avatar
silver bullet80 is on a distinguished road
ok thank u very much. so it is a possibilty that the cmp may be acting up again. and getting some new heat grease behind my icm would be a good idea too right? thanks alot for your good info!!! and sorry about not editing
now that i think of it it does seem to be worse once the truck is warmed up after going down the highway. blazer has over 275,000 miles and i belive icm and coil all original
Old May 24, 2011 | 02:58 PM
No problem. Try the ICM grease and see how it goes.
Old May 24, 2011 | 03:03 PM
thanks ill try that tonight. did u see my edit on how i think it does get worse once warmed up? but the sluggish start seems to be timming like i need to twist the cap just a tad. but then it makes me think cmp cause when i removed my cap and installed new one the starter was not sluggish? this truck is crazy lol.
Old May 24, 2011 | 10:18 PM
well i tried the grease and still the same. i did notice when i had my dist. cap off that the rotor had play from side to side and up and down. is that normal?
Old May 25, 2011 | 07:31 AM
Some play is normal. There shouldn't be much up/down movement.
Old May 26, 2011 | 12:20 PM
ok so let me ask u this. how come when i changed my CMP under dizzy cap the first time my blazer would start right up no problems at all then 2 days later right back to the sluggish start and missing out?
Old May 26, 2011 | 12:40 PM
Could be a wiring fault... Intermittent problems are never fun to diagnose.
So hypothetically, the replacement of the CMP sensor would require the disconnection of the wiring which will move the wires around in the harness. This movement could have temporarily allowed for a broken wire to once again pass current properly, allowing the truck to run.
Old May 26, 2011 | 12:44 PM
ok. it seems i have about as much play up and down in dizzy as side to side.
Old May 26, 2011 | 12:47 PM
You could pull the distributor and inspect the gear on the bottom...
Old May 26, 2011 | 12:49 PM
whats the easiest way to get that 9/16 bolt out? can i just remove cap and possibly get a 9/16 socket and swivel?
