95 blazer vacuum line mess
Old Apr 13, 2009 | 02:35 PM
intoodeep95's Avatar
intoodeep95 is on a distinguished road
Default 95 blazer vacuum line mess
i recently purchased a 95 blazer with a 4.3 vortex, 4wheel drive, and when i looked under the hood the vacuum lines were cut and torn all apart!! i need someone to help me with diagram or pictures of the vacuum lines coming from the right side of the motor. i need to know which lines are connected to what. any pictures or diagrams of hoses. and i'm not looking for emissions but the vacuum lines coming from out of the back of the engine and coming from the transfer case.
Old Apr 15, 2009 | 10:35 AM
banshee386's Avatar
banshee386 is an unknown quantity at this point
i am waiting to find out that same question and havent heard from anyone i went to a junk yard and found a 1995 blazer motor to look at to find out the big line on the back of the motor goes to the line coming of of the brake booster bye the master cyninder the little line on the back goes to the charcol can mounted on the hood any others i can check my pics i took for ya
Old Aug 25, 2010 | 02:53 PM
rustfarmer's Avatar
rustfarmer is on a distinguished road
I also need to know where the three vacuum lines coming from the transfer case vacuum switch go and what do they do? Need a way to tell which of the 3 lines goes where. Seems as thou there should be a diagram somewhere but I have found none.
Old Aug 25, 2010 | 03:19 PM
737mechanic's Avatar
737mechanic is on a distinguished road
Not sure if your guys blazers are california or federal so I printed everything I have. Look at the codes at the top of the page to figure out what you have. They are pdf files so you will need adobe acrobat reader.
rustfarmer The file named 1995 axle.pdf is for you.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
heres the vacuum diagram for the engine - http://a.imageshack.us/img163/5227/61513839.png
and the diagram for the transfer case - http://a.imageshack.us/img841/7210/26203923.png
Old Aug 26, 2010 | 07:13 AM
rustfarmer's Avatar
Thank you very much for the images. Exactly what I need.
Old Sep 10, 2010 | 08:28 PM
chucky blazer's Avatar
chucky blazer is on a distinguished road
thank you guys, i have been all over looking for his stuff.
Old Oct 11, 2010 | 12:32 PM
jochumson's Avatar
jochumson is on a distinguished road
ya THANK YOU
Old Nov 4, 2010 | 08:56 PM
stormynarramore's Avatar
stormynarramore is on a distinguished road
I understand what the 3 fittings are for, but what I don't know is which lines go on which nipples? Is there any way to determine which nipple is for the vent, vacuum supply and front axle actuator?
Thanks,
Stormy
Old Jan 26, 2011 | 07:01 PM
trhester's Avatar
trhester is on a distinguished road
Exclamation
Thanks,
Stormy
Can Anyone Answer This? I Have the Same Question
