95 blazer vacuum line mess
Old Jan 26, 2011 | 07:04 PM
This should help:
I have a vacuum switch cut apart on my work bench, but haven't had the time to snap some pictures.
Old Jan 27, 2011 | 08:05 AM
trhester's Avatar
trhester is on a distinguished road
Perfect. Thank you very much.
Old Jan 27, 2011 | 06:15 PM
trhester's Avatar
Since replacing an open vacuum line to the transfer case switch, then replacing the switch because no vacuum coming out, I've discovered the vacuum is sucking all of the trans fluid out and into the intake manifold. (Smoking exhaust like it's on fire!) Rather than replacing the input shaft seal, I've disconnected the vacuum for the switch and the transfer case vent, and left them open to air. Is there any harm in this? I can live without 4wd for now. And do you concur that it is most likely an input shaft seal and how can I prove that?
Old Feb 22, 2011 | 01:21 PM
Paulie's Avatar
Paulie is on a distinguished road
Thanks Bro, This was just what the doc ordered. I have been having a hell of a time finding the help I needed and the pdf files you put up were perfect i am sure for all! Thanks again, Paulie
Old Jul 22, 2011 | 07:35 PM
Ron cb's Avatar
Ron cb is on a distinguished road
Hello; I can not find the AC vacuum line that goes to the motor.... i need some help!!
Old Jul 23, 2011 | 08:47 PM
rival904's Avatar
rival904 is on a distinguished road
Where does the other end of the HVAC vaccum line connect to?
Old Jul 24, 2011 | 07:14 PM
trhester's Avatar
I believe you may find that diagram if you look back at previous posts. There are several .pdf drawings of vac system.
Old Nov 9, 2012 | 08:53 AM
balaku360's Avatar
balaku360 is on a distinguished road
Default Thanks
Thank You everyone who posted the information with the vacuum diagrams, that was exactly what I needed to get the 4 wheel drive operational again for my buddy's rig, he had bought it and whoever owned it before obviously was in a accident and the the person who did the repairs to the rig should be banned from ever touching another car again....unbelievable the quality of the work they did......found the vacuum lines all cut and either hidden out of sight or plugged and....thanks everyone 4x4 is working once again in time for the winter season here in Washington State.....
Skitzoape
19
Apr 8, 2014 11:34 AM
Blazer_boy
Nov 23, 2009 03:26 PM
redneck2725
Aug 11, 2009 04:01 PM
Red03
Suspension Tech
Sep 20, 2008 09:25 AM
strongboy2005
Feb 18, 2006 11:07 PM
