95 blazer will not charge
Old Jun 18, 2010 | 03:42 PM
frostblazer's Avatar
frostblazer is on a distinguished road
Question 95 blazer will not charge
i have a 95 blazer the other day is started running ruff then when i went to restart it was dead. I thought the alternator was gone but after replacing it twice i found it wasnt the problem the battery is good as well any other ideas on why this would not charge ive geard the fusable links but is there any other issues with these thanks
Old Jun 19, 2010 | 03:29 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
You have a fusible link betweenyour alternator and battery on the red wire that ties into your positive battery cable. With the engine running see if you read about 14 volts on the wire coming out of your alternator and then at the positive cable at the battery. If they're different, you probably have a bad or broken connection or a burned fusible link. You have another in the circuit between the alternator and the junction block on you firewall (red wire too).
Izzy207
Jul 30, 2011 04:34 PM
bdepue
Dec 27, 2010 03:05 PM
perplutt
Aug 10, 2010 05:20 AM
dirtracer94
Jul 20, 2010 08:08 PM
dbldown768
Jun 29, 2010 12:59 PM
