Blazer 97 do not charge :(
Old Aug 9, 2010 | 01:19 PM
perplutt's Avatar
perplutt is on a distinguished road
Default Blazer 97 do not charge :(
a question from Sweden, the battery light is on, checked alternator brushes, saw the fine,
according to the meter charge it or not almost 11 volts when the car goes
what else can I check,
as in Sweden
ps: read English better than I write
Old Aug 9, 2010 | 01:59 PM
whyteb0y's Avatar
whyteb0y is on a distinguished road
I would check the battery, is the water level OK? Then I would check the connections, both at the battery and at the alternator, do they look corroded or anything? Then I would check the ground wires. Another thing, do you ever smell like a sulfur or rotten egg smell? If you do, that's a good indicator that your battery is bad.
Old Aug 9, 2010 | 02:12 PM
perplutt's Avatar
I have checked the battery, it's okay. checked the ground wires to the instrument and they are as they should. electrical fault, I am not wise on
Old Aug 9, 2010 | 07:28 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Sounds like the alternator is bad you should be putting out 13.5 to 14.5 volts if your getting 11 volts you are just reading battery voltage. Get alternator tested!
Old Aug 10, 2010 | 05:10 AM
perplutt's Avatar
Fixed
Lightplate and shargeregulator
$ 80 poorer but of course the bastards charge like hell
per in sweden
Old Aug 10, 2010 | 05:20 AM
Topsecret66's Avatar
Banned
Topsecret66 is on a distinguished road
good job!
Izzy207
Jul 30, 2011 04:34 PM
bdepue
Dec 27, 2010 03:05 PM
dirtracer94
Jul 20, 2010 08:08 PM
dbldown768
Jun 29, 2010 12:59 PM
frostblazer
Jun 19, 2010 03:29 AM
