95 Blazer won't start or stay running
Old Mar 12, 2008 | 07:10 AM
Lazt36's Avatar
Lazt36 is an unknown quantity at this point
Default 95 Blazer won't start or stay running
I have a 95 Blazer with a Vortex engine with about 140000 miles. 1st it would stall out at idle, plus it would stall out while driving and start running again without stopping. Now it won't start. When I turn the key to the on position it would be clicking on and off like a electrical problem. Now when i turn the key the fuel pump won't even tun on and it won't turn over. the check engine light dosen't come one but the other lights do. the fuel pump is 3 months old with the sending unit plus TPS ignition mod. and crankshaft sensor. I have tested the map sensor and it ok. It will Start up again eventualy. Does anyone have any Ideals.There are no codes, but it was hooked up to a $50 code scaner.
LazT36
Old Mar 12, 2008 | 07:26 AM
Default RE: 95 Blazer won't start or stay running
How does it run when it is running? Sounds like you might have a vacuum leak or a clogged EGR valve.
Old Mar 12, 2008 | 07:56 AM
Lazt36's Avatar
It runs fine for how long it runs. But would the EGR make the electical mess up to? because it would click on and off with the key in the on position
Old Mar 12, 2008 | 08:28 AM
No, it wouldn't. What do you mean by "it would click on and off with the key in the on position"?
Old Mar 12, 2008 | 08:57 AM
Lazt36's Avatar
its like someone is shaking the bat cable. all the dash lights would go on and off plus i can hear the feul relay clicking on and off
Old Mar 12, 2008 | 09:17 AM
When the engine is running, the alternator should be supplying more than enough juice to run everything, plus feed back into the battery, recharging it if necessary.
I would start by checking all of your connections at the alternator and at the battery, cleaning them and coating them with dielectric grease. See if that helps.
Old Mar 12, 2008 | 12:01 PM
Lazt36's Avatar
The alternator is good and the battery and cables are fairly new and clean. I am just wondering if the ignition switch might be going
Old Mar 12, 2008 | 01:11 PM
It is a possibility. Just don't hear that much about ignition switch failures in the pre-96 models.
Old Mar 13, 2008 | 05:11 PM
Lazt36's Avatar
Well I broke down and took it to the dealer! They found a broken wire in the insulation, on the main wiring harnes behind the fire wall and over the tranny. so I think i woulden't found that. But it still cost mee $380. Boo Hoo, but its done. Thanks for all the help.
grapeape3
Aug 19, 2012 03:25 PM
turbotype87
Jul 16, 2011 09:15 PM
thays0407
Mar 8, 2011 03:55 PM
Dizgt
Sep 10, 2007 09:21 PM
jes9999
Mar 12, 2006 01:40 AM
