95 engine compatibility ?
Old Mar 17, 2011 | 09:49 PM
sscandyman's Avatar
sscandyman is on a distinguished road
Default 95 engine compatibility ?
i have a 95 blazer with no motor but 3 vortecs laying around and was wondering if any of them are a straight swap or would require minimal hassle to work. this would be my first engine swap and would prefer not to get too far over my head .
93 bravada
94 bravada
and an engine out of a 96 blazer.
any advice or links to info would be much appreciated
thanks!
Old Mar 18, 2011 | 05:33 AM
The 96 engine won't work without serious modifications.
The 93 & 94 engines may work, but it depends on what ignition & computer system your truck was originally equiped with. The full OBD1 setup would be able to use the 93 & 94 engines as they are. But I believe that the OBD1.5 & OBD2 setups had the enhanced ignition system which required a crank position sensor. The CKP required a different timing cover and the presence of a reluctor ring on the crank.
Old Mar 18, 2011 | 10:23 AM
sscandyman's Avatar
Well I guess the next step is figuring out which variation I have. Wish it was a 96 I have all those components setting on a twisted frame lol
it appears i have either the obd2 or obd1.5 judging by the obd2 shaped dash plug.
is it possible to essentially convert the 95 to a 96 using the wiring , engine tranni etc off of my totaled 96 ? im more of a fan of the later vortec but budget demands if i want a blazer any time soon it has to come from the 4 junkers i have laying around.
Last edited by rriddle3; Mar 18, 2011 at 05:54 PM. Reason: COMBINING CONSECUTIVE POSTS
davidkeith77
Feb 17, 2025 12:35 PM
seriosbrad
Nov 15, 2014 08:46 AM
eriktburbank
Feb 26, 2014 02:12 PM
lroman3
17
Feb 9, 2013 05:14 AM
EMTBlazer
Dec 3, 2006 07:13 PM
