95 s10 blazer 4wd problem
Old Oct 4, 2011 | 01:27 PM
lukeawilliamson's Avatar
lukeawilliamson is on a distinguished road
Default 95 s10 blazer 4wd problem
I have a 95 Blazer (4.3L V6) that won't go into 4WD. When I press the push button for 4 high or 4 low, both lights will blink a couple times and then both lights will come on and it won't kick into 4WD. Any suggestions?
Old Oct 4, 2011 | 06:04 PM
Lrain88's Avatar
Lrain88 is on a distinguished road
have you checked the actuator?
Old Oct 6, 2011 | 12:08 PM
Thanks for your suggestion Lrain88, I checked the actuator and noticed that the vacuum line coming off it was cut in 2 pieces (it was melted- probably touched the engine or exhaust). After tracing the line I noticed another break in another line coming off the vacuum plug on top of the transfer case. I replaced both lines and found out that the electrical plug, which is a screw in plug, was not connected either. Needless to say, now I have 4Wd again. Thanks!
Old Oct 11, 2011 | 08:35 PM
Lrain88's Avatar
no problem glad to help and glad you have some 4x4 blazer power!
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
AMACK
Nov 24, 2010 06:42 AM
chexoe
Apr 7, 2008 07:02 PM
thaasjr
Nov 13, 2006 02:03 PM
thaasjr
Oct 12, 2006 07:26 PM
