General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
95 s10 blazer 4wd problem
Old Oct 9, 2006 | 09:50 PM
thaasjr's Avatar
thaasjr is an unknown quantity at this point
Default 95 s10 blazer 4wd problem
Hi,
I have a 95 blazer 4wd. It has the push button 4wd. It has been doing some weird things that I can't figure out. I was driving down the highway the other day and the 4hi light came on by itself. I pulled over to check it out and the 4wd was not engaged but the light was on. When I pushed the 2wd button it would not light back up. I can get it into 4lo and back out easily. Sometimes when I hit the 4hi button the 4lo and hi lights both come on at once. I eventually got the 2hi light to come back on and just pulled the fuse so I didnt have any problems. 4lo seems to work fine and 4hi is not working no matter what the lights indicate. How to I fix this problem. It sounds like it is in the switch to me. Has anyone else seen this?
Thanks for any suggestions
TOM
Old Oct 10, 2006 | 04:24 AM
Chevy Lover's Avatar
Default RE: 95 s10 blazer 4wd problem
That's a tough one to diagnose without a scanner. Could be the encoder motor or the Transmission Shift Control Module.
Old Oct 10, 2006 | 10:31 AM
firststep's Avatar
firststep is an unknown quantity at this point
Sounds like the problem I had with my 95 Blazer. When I put it 4 wheel low,I couldn't get it out without turning off the power. Sometimes driving,even as fast as 60mph it would go into 4 wheel low by itself. It turned out to be the encoder motor. I replaced it a year ago and everything is fine.
Harry
Old Oct 10, 2006 | 11:20 AM
thaasjr's Avatar
How much is the encoder motor and can I test it. Where is it located on the truck and what does it look like.
Thanks again,
TOM
Old Oct 10, 2006 | 02:43 PM
thaasjr's Avatar
After research I think it is the transfer case motor. What year blazers are interchangeable with my transfer case motor. Mine is a 95
Thanks
Old Oct 12, 2006 | 07:26 PM
thaasjr's Avatar
Do I need a blazer with a push botton 4wd for this part or will one with the floor mounted handle to operate 4wd work just the same. Thanks in advance for any timely help. I want to find one in a junk yard this weekend.
Tom
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
lukeawilliamson
Oct 11, 2011 08:35 PM
AMACK
Nov 24, 2010 06:42 AM
chexoe
Apr 7, 2008 07:02 PM
thaasjr
Nov 13, 2006 02:03 PM
