96 4.3 swap 2wd vs 4wd
Old Nov 20, 2015 | 07:28 PM
Tntlewis's Avatar
Tntlewis is on a distinguished road
Default 96 4.3 swap 2wd vs 4wd
I have a 96 blazer with a 4.3 that i am getting ready to change the engine on. It is 4wd and i have located a 4.3 out of an s10 but it is 2wd. I know i will have to change the oil pick up and pan over but there is one thing i havent got a answer to.
Is the bell housing for the 2wd and 4wd the same?
Old Nov 20, 2015 | 08:32 PM
richphotos's Avatar
I think it is the same, I cant be quoted on that though.
Old Nov 20, 2015 | 08:41 PM
bulldog565's Avatar
bulldog565 is on a distinguished road
yes it is the same as I have a 96 Gmc Jimmy and the engine I have in it came out of a 2wd
you will also have to swap the oil cooler adapter from you old 4wd engine to the 2wd engine.
Old Nov 20, 2015 | 10:24 PM
Bell housing is the same.
You may also need to swap over the PCV port adapter on the upper plenum. Compare them to make sure the "new" motor has the same number of nipples.
Old Nov 20, 2015 | 10:36 PM
odat's Avatar
Also when you change out the pan if you read the instructions that comes with the new gasket and it says install dry with no sealant remember not everything you read is true and correct, seal it the old school way or it will leak - don't ask me how I know this lol
Old Nov 21, 2015 | 12:09 AM
LeWhite's Avatar
I have had the exact opposite experiance especially when not following manufacturers instructions.
Old Nov 21, 2015 | 12:35 AM
odat's Avatar
In most cases I agree 100% but I"m not the only one on this sight that has had too redo them the old school way using a little RTV - mainly they leak at the front around the U gasket
badmtrsc2r
Feb 10, 2012 11:40 PM
Darren Spevak
Mar 8, 2011 12:00 AM
an240172
Sep 7, 2009 02:58 AM
DUI Motorsports
Oct 23, 2008 05:55 PM
95_4door
Oct 21, 2008 12:30 PM
