96 4.3 vortec with odd engine miss
Old May 24, 2010 | 06:53 PM
larrya97's Avatar
larrya97 is on a distinguished road
Default 96 4.3 vortec with odd engine miss
I have a 97 jeep that i put a 96 4.3 v6 engine and a 4l60e transmission with all the emissions, orginial wiring from the chevy blazer, the fuel lines the fuel pump, sender and gauges, and the instrument panel from the blazer. all hooked up and working. it is throwing no codes. the problem is it has a miss when you just start to push and hold steady on the accelerator, but if you just rev it up no miss. doesnt matter if it is in drive or park acts the same. the odd part is after about 45 minutes of driving it stops missing almost completely. I have changed the spark plugs, the cap, the rotor, the wires, have swapped working coils, pickups, tps, map, maf, egr, iac, off of same year and model working chevys, to no avail. also the motor is a new rebuild all new gaskets and o rings. I hope someone can shed a little light on the problem. thanks.
Old May 24, 2010 | 10:47 PM
It is possible that there is an issue with the spider not spraying consistently... Have you run a rather stiff regiment of injector cleaner through it?
Old May 25, 2010 | 08:10 AM
larrya97's Avatar
i haven't yet. so it could be possible, but i didn't see anything wet inside the manifold when i took off the tb and looked inside. but i will try that and see if it helps.
Old May 25, 2010 | 07:35 PM
larrya97's Avatar
anyone with any other ideas, or suggestions. need all the help and input i can get. thanks
WhitetailHunter
Jan 15, 2015 09:32 PM
ussexplorer
Sep 27, 2013 03:38 PM
onebadblackz28
Aug 16, 2012 10:45 PM
89GMCJames
Feb 23, 2011 12:26 PM
Bojib
Apr 2, 2006 05:04 PM
