96 4dr & low temp gauge reading
Old Feb 8, 2011 | 06:37 PM
Mark_D's Avatar
Mark_D is on a distinguished road
New thermostat fixed me right up. Running at a normal 195-200 degrees.
Hope it helps you too! Let us know
Old Feb 8, 2011 | 07:20 PM
das96blazer's Avatar
das96blazer is on a distinguished road
What did you use.... a 195 degree thermostat
Old Feb 9, 2011 | 06:56 AM
Mark_D's Avatar
Yes, it is a 195 degree t-stat from Napa. Good luck!
I was trying to finish before dark but had to reconnect everything and go to the hardware store for a deeper 13mm socket in order to remove the t-stat cover. Ended up having to buy a work light too lol...
Old Mar 1, 2011 | 08:48 PM
rob44_90's Avatar
rob44_90 is on a distinguished road
Looks like I'll be replacing my thermostat some time next week. I believe it went out last weekend, because since then my temp reads at the 1/4 position no matter how I drive.
Old Mar 1, 2011 | 09:26 PM
CO Chevy Dude's Avatar
CO Chevy Dude is on a distinguished road
I just saw this thread and want to confirm Mark_D's findings. I went through the same thing about 4 years ago on mine. Third stat finally fixed it.
Old Mar 2, 2011 | 06:36 AM
Mark_D's Avatar
rob44 -
The only downfall I can think of for waiting a week to do the t-stat is that your gas mileage is going to come down. My truck is usually around 17.9-18 mpg on average but with the broken thermostat it was getting closer to 15. Good luck!
Old Mar 2, 2011 | 09:43 AM
rob44_90's Avatar
Well, I have to wait, because all of my tools are sitting at home. I'm in college, about 90 miles from home. But next week is spring break, so I'll have all the time I need to swap them out. Any chance you could briefly describe what you had to do to change it? I've never changed one of these before, but I'm sure it's fairly simple. My fuel mileage hasn't noticeably changed, I still get 13-15 mpg with my lift and tires.
Old Mar 8, 2011 | 06:52 PM
rob44_90's Avatar
Well, that was easy. The thermostat is located to the left the egr valve if anyone wants to know. The Napa Premium 195 degree thermostat worked perfect for my rig.
Old Mar 9, 2011 | 05:21 PM
step66's Avatar
By the way,the reason one should never over-compensate on coolant is because all coolants gel instead of freeze-but one still needs the thining effect the water gives at even at -70*(the coldest I ever started any gas engine,the battery was kept inside for the night) step66
ssmith5399@nc.rr.com
Feb 6, 2013 10:13 PM
WalkGood
13
Jun 13, 2012 10:39 AM
zakm0n
Jan 9, 2011 07:31 PM
bertrenolds
Dec 19, 2008 07:45 PM
ant2297
Sep 28, 2008 07:40 PM
