96 Blaser cranks but won't start
Old Mar 6, 2010 | 06:06 PM
dfehrman's Avatar
dfehrman is on a distinguished road
Default 96 Blaser cranks but won't start
I have a 96 Blaser, 4.3L, 6 cyl, 219,000 miles that will crank but won't start.
Sometimes it seems like there is a light backfire under the hood when starting. Before this I had a rattling sound under the passenger side of the vehicle and bad gas mileage.
I've been told it may be the Catylatic Converter and to drill a 1/4" hole in the front of the converter so I can start it to get it to the shop.
I tried that and still it won't start and doing the same as above.
It went from starting great one day to nothing the next.
I'm a great machinist but stink at mechanics.
Does any one have any suggestions ?
Thanks for your time and help,
Doug
Old Mar 6, 2010 | 06:33 PM
Al3x's Avatar
Al3x is on a distinguished road
You need spark, air, & fuel to start. Check your sparkplugs and wires. I think you can pull one out to see if it's sparking too. If that seems fine...check fuel filter maybe? I've seen people with 175k miles on the same fuel filter they had when they bought it. Hope this helps!
Old Mar 6, 2010 | 07:15 PM
dagda's Avatar
dagda is on a distinguished road
I had a similar problem with my 96 with almost the same amount of miles. The rattling was the cat on mine. When mine was cranking and not starting, I changed the fuel pump, fuel filter, and cleaned the distributor cap. After all that it still didn't start. I then turned to the first thing I should have checked, the spark plugs. I changed those and it started right up. Don't forget the simple things.
Old Mar 7, 2010 | 05:41 AM
dfehrman's Avatar
Default Thanks Al3x & dagda
Thanks for your help guy's.
Being a machinist, CNC programmer, a rotten mechanic and trying to build something an engineer has put on paper, I always find myself having to think out of the box. Sometimes simple is hard for me.
I'll try changing the spark plugs today if I can get to them and I'll let you know later how I made out.
Again, thank you for your time & help,
Doug
Rhodes19
48
Feb 15, 2013 09:46 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
sindy1232
Jul 25, 2008 11:59 AM
99whiteblazer
13
Jan 8, 2008 06:45 PM
