96 Blazer 4.3L
96 Blazer 4.3L
96 Blazer 4.3L 4DR/4WD
Air compressor is locked up, air hasn't worked in years anyway, so I just want to bypass the compressor.
Does anyone know what size belt (part # / brand) this belt would be, if I'm not removing the compressor and adding a bypass pulley?
Any help is appreciated.
Thanks in advance.
Thanks in advance.
Read this thread:
https://blazerforum.com/forum/2nd-ge...ne-belt-41726/
Also, you tend to get more interest and help if you title your threads with something that lets members know what the thread concerns.
that's strange..whenever I have used the by pass pulley the existing belt worked..if the pulley diameter is the same then it should work with your old belt..I'd check out the pulley diameter and go from there...good luck. Jerry
Howdy!
Probably won't help now that you installed the bypass pulley, but I had my compressor lock up last year and I'm driving with the compressor in place, but electrical connectors disconnected and ac clutch (plate?) removed. This allows me to keep driving with the ac system sealed until replaced/repaired properly, and can still use heat/vent. Here's a link to the thread I posted:
https://blazerforum.com/forum/2nd-ge...c-w-4wd-87461/
