96 Blazer cranks but no start
First off, I'm new here so I apologize if this has been discussed before.
Before the no start it had a rough start then all of a sudden it wouldn't start at all unless I put a little gas into TBI then it runs til that burns out.
We have changed the fuel pump, fuel filter and spider injector and now I'm stuck and don't know where to go next.
What do you guys recommend I do next to try to get this problem resolved?
Btw I should mention that the spider injector came from the junkyard so could it be possible that I just got a bad injector?
Ok..thanks for the info, I am getting pressure at the rail, not sure of the exact reading but as soon as I have a reading I will update.
If you do not have a test gauge most part stores have a loan out program just have too put down a deposit. do all the checks in sticky not just one at the test port these engines are picky on fuel pressures
Ok..Will do, and I will post the results..thanks again for the input
kwbond
03-18-2014 12:39 AM
nyjeepman
34
03-15-2009 07:40 PM
apekim
06-30-2006 10:38 AM
