'96 blazer HVAC vacuum query
Old Jun 22, 2009 | 08:53 PM
baronthered's Avatar
baronthered is on a distinguished road
Default '96 blazer HVAC vacuum query
Glad I found this board. I've been doing some research here and now have some specific questions about this Blazer. 4WD w/air 4.3l. I have read here that the vent system defaults to the floor when no vacuum is present at the switch. I have both the floor and defrost vents blowing. Does the fan blow faster when the switch is set to High AC? It has been so long since I have had air working that I can't remember what it does. I'm guessing from what I have read so far with both the floor and defrost vents blowing air I prolly nead s new switch. Just to cover all my bases can someone tell me where the vacuum lines go through the firewall? I'm trying to get this done between thunderstorms and everytime I barely get the hood up and started good before another squall is upn me. I'm not used to the way GM/Chevy does things and often I am unsure what and where to look at. Thanks in advance.
Old Jun 22, 2009 | 09:07 PM
mahoney1988's Avatar
mahoney1988 is on a distinguished road
im not sure where they come threw the firewall but i do know that when i put mine in max ac it does blow faster.. when i got my blazer the dumb guy didn't have my lines hooked up he had a screw in on of the lines to block the air.. idk why someone would do that but anyways.. if you need me to look on my blazer for where the vacuum lines come out i can tomorrow after work.
Old Jun 23, 2009 | 01:06 PM
Thanks. I appreciate it. Does anyone have the full diagram as it relates to the Vac/ac system handy?
Old Jun 24, 2009 | 01:08 PM
Anyone? Hello?
Old Jun 24, 2009 | 07:01 PM
I have never found a good diagram in any of the references that I have for the complete vacuum hose system. There are, however, several other threads where I have posted the under dash vacuum hose schematic.
I believe that there was only the manual HVAC offered in 96.
Here is a diagram for the manual HVAC system in a 97 which should be the same as yours:
Attached Thumbnails '96 blazer HVAC vacuum query-97_hvac_diag.gif   '96 blazer HVAC vacuum query-97_hvac_sch.gif
Old Jun 25, 2009 | 12:15 PM
Thank you very much. Now I should be able to get this thing fixed.
JMorton
Apr 6, 2011 07:19 AM
daddyb1
Jun 15, 2010 12:40 PM
starcruiser
Oct 17, 2009 10:52 AM
MATHEWSMAN1969
Jan 17, 2009 06:19 PM
94pos
Aug 9, 2007 04:00 PM
