heater control switch
Old Jan 11, 2009 | 10:38 PM
MATHEWSMAN1969's Avatar
MATHEWSMAN1969 is an unknown quantity at this point
Default heater control switch
hey guys,
When i select the upper vents on my 96 Blazer nothing comes out. The defrost and the floor vents work great,also the truck doesnt get hotter than 15o degrees.Are the vents vacuum actuated, if so how would i find the problem
thanks
[IMG]local://upfiles/13639/F85BFE3933F44B998FB60D24A90088B0.jpg[/IMG]
Old Jan 12, 2009 | 06:39 AM
Default RE: heater control switch
When you change modes on the HVAC controls, do you hear things changing in the dash or does air only come out of the defrost and floor vents regardless of HVAC control position?
Yes, most of the actuators for the HVAC system are vacuum actuated. A vacuum problem in the supply line would force the system to its default position which is defrost + floor.
Old Jan 12, 2009 | 12:46 PM
yeah its only floor and defrost no matter were hvac is,its not making any noise in the dash at all.are the supply lines up in the dash or under the hood?
Old Jan 12, 2009 | 01:12 PM
Vacuum supply comes from the engine.
Old Jan 17, 2009 | 06:19 PM
RuralRoute's Avatar
RuralRoute is an unknown quantity at this point
Several good posts on this subject...https://blazerforum.com/m_110485/tm.htm, that said...I flushed my 99, radiator, block, and heater core today, replaced the thermostat w/ 195 deg new and coolant, and went from 80deg output to 160deg! Truck had recently started running cool, I suspected weak / wide open thermostat. Now reading 197deg at thermostat housing, 150deg radiator inlet, 95deg outlet(60 deg outside today), Temp gauge reading about 200deg.
My selector switch had also quit working, verify that the vacuum line located near ABS unit... near the driver fender is attached...you can test by blocking it off...mine had come loose and was just enough of a leak to affect my selector switch, all is now good again!
brians1bad72
Mar 31, 2011 05:09 AM
brians1bad72
Jan 25, 2011 12:37 AM
cage47
Mar 25, 2010 07:40 PM
rescueray
Jan 18, 2010 09:25 AM
matclark
Oct 18, 2008 10:14 AM
