96 blazer missing that electric hum and will not start
Old Jul 13, 2008 | 08:07 AM
Greenman's Avatar
Greenman is an unknown quantity at this point
Default 96 blazer missing that electric hum and will not start
Truck ran fine Friday but Sunday morning it will not start.
The engine is turning over, battery checks out alright.
-There is a missing electrical hum when I put the key in and turn it, however. I'm not certain if this is the fuel pump.
-The fuel gage goes to full, however I'm pretty certain it was at a quarter tank when I drove it last.
-The battery charge indicator does not move, either. I am pretty certain it jumped when I turned the key before this problem occured.
95/96 Chevy Blazer.
Funds are tight so I cannot Easter Egg. Anyone have an idea, please?
Steve
Old Jul 14, 2008 | 08:35 AM
Smoked's Avatar
Smoked is an unknown quantity at this point
Default RE: 96 blazer missing that electric hum and will not start
You should do a fuel pressure test. A quick search will give you the numbers you need to see and how to do the test.
Old Jul 14, 2008 | 12:14 PM
if6was9's Avatar
if6was9 is an unknown quantity at this point
If you don’t hear the ‘hmmm’ before start up, that means the fuel pump isn’t working. Check the fuse first; if that’s ok I’d suspect the pump is dead. It’s a PITA to replace since the pump is in the tank. Fuel injected cars need constant psi to run, so manufactures had to go electric. The electric pumps do a better job at pushing fuel than pulling. So they mount them in tank. Also it helps cool the pump. Try replacing one in the dead of winter with a full tank of gas (27 gal) in a K1500, and nowhere or means of putting the fuel anywhere.
mkm1387
Jul 28, 2014 07:25 AM
toyblazervt
Nov 28, 2010 05:07 PM
DoubleDD
Jan 24, 2008 09:25 PM
punx.inc
Dec 25, 2007 12:07 AM
92teg92
Dec 31, 2006 07:38 AM
