96 blazer window motor
Old Jul 14, 2008 | 08:37 AM
RockT's Avatar
RockT is an unknown quantity at this point
Default 96 blazer window motor
1996 blazer passenger window doesn't work.; Window is in down position. Using multimeter I checked voltage to window motor connector and its is good to go, therefore its the motor. PROBLEM. I can buy a window motor on Ebay or AutoZone - it comes as window motor only. However, on the vehicle, the motor is rivited to the entire window apparatus. What do I do? Drill rivits out and bolt in new motor? Putting nut/bolt in here isreally tough. IDEAS?
local chevy dealer wants to charge me $250 for labor alone.
thanx
tim
Old Jul 14, 2008 | 08:39 AM
Default RE: 96 blazer window motor
You have to remove the regulator, drill the rivets, remove the motor, then bolt the new motor on and reinstall the regulator.
Old Jul 14, 2008 | 08:44 AM
RockT's Avatar
Is there anyway to get window up until I repair it?
tx
tim
Old Jul 14, 2008 | 12:28 PM
Yooper's Avatar
Yooper is an unknown quantity at this point
I just had this same problem. I removed the door panel and then held the up switch and banged on the motor with a screwdriver handle until it went up.
Shizzinizz
Apr 14, 2014 08:50 PM
sweaver
Jul 27, 2010 02:33 PM
ronjones46
Sep 8, 2008 11:26 AM
rob1621
Feb 29, 2008 08:15 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
