96 blazer rear wiper spray
Old Sep 4, 2019 | 08:45 AM
Czechman90's Avatar
Czechman90 is on a distinguished road
Default 96 blazer rear wiper spray
The front wiper sprays.then when i go to spray the rear wiper nothing, but a puddle on the ground. Does anybody have a clue what could be the problem,Or have a diagram.
Old Sep 4, 2019 | 02:26 PM
Does it not come out of the nozzle that is on the rear wiper blade? If it is coming out of the bottom of the rear lift window or liftgate, then you likely have a broken fitting inside the rear lift window or lift gate.
Old Sep 4, 2019 | 03:21 PM
LannyL81's Avatar
If no spray from rear nozzle; open tail or lift gate, pop off the bottom trim piece at the "bed" carpet edge, look into the access hole for the wiring and you will find the washer line. Usually the hose just comes off the elbow, but you may have to splice in a new section of hose. Easy fix.
Old Sep 5, 2019 | 11:34 PM
N. Jensen's Avatar
I agree with Christine and Lanny.
On my liftgate, it was the same problem with puddling. The fix was just to the right of the rear ceiling cargo light. Popped that trim down, and added some newer tubing, since my old stiff had split. Works great 4+ years later...now to get my rear wiper motor back to working order.
AKPerry
Oct 21, 2011 02:12 PM
wcolclou
Mar 4, 2009 09:29 PM
poppa
Dec 26, 2008 08:29 PM
thaasjr
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Dec 10, 2008 06:43 AM
dardamar
Nov 8, 2008 11:19 AM
