96 blazer water pump
Old 08-28-2009, 01:45 AM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default 96 blazer water pump
Hey guys, i need to change the water pump 4.3 blazer 4x4 . When looking down at the fam I see the 4 bolts holding the fan on, Can I remove the drive belt and those 4 bolts then take the fan off? to get to the water pump?
I have searche the forum and still now definite on this. And alldata it not helping.
Old 08-28-2009, 02:04 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
those 4 bolts hold the pulley onto the water pump
i'm pretty sure they hold the fan on to and you wont need a fan clutch tool but i could be wrong, i've been outa cars for awhile now
i know you pull the radiator shroud off then the fan, then the water pump is right there 6 or 8 bolts hold that in
Old 08-28-2009, 03:22 AM
Beckyj636's Avatar
Is this a reverse rotation Pump?
Old 08-28-2009, 05:53 PM
You will need a fan clutch tool to remove the fan & clutch. The bolts just hold the pulley on. The end of the water pump is threaded for the fan clutch.
As far as reverse rotation goes, I believe that all serpentine belt driven 4.3L engines are reverse rotation water pumps. There should only be reverse rotation pumps available for your year regardless of whether they state it in the description or not.
anthonyspain
02-12-2010 04:23 PM
shesrdy2laff
10-14-2009 12:46 AM
jonesjamesw
07-07-2008 10:28 PM
green75
10-11-2007 08:47 AM
45auto
08-18-2006 03:09 PM
Quick Reply: 96 blazer water pump
