96 blazer wont start has good spark and fuel
Old Jun 25, 2013 | 02:06 AM
1996chevyblazer's Avatar
1996chevyblazer is on a distinguished road
Default 96 blazer wont start has good spark and fuel
Last saturday i was driving home, and my 96 blazer randomly died check engine light went on and then wouldnt start back up it only cranks and cranks
had towed home.
tested had low fuel pressure around 30 psi
put fuel pump in then had good fuel pressure around 50 psi
still cranks only so then i found my distributor mounting ears were cracked so i ordered a distributor rotor and cap
timed and installed same thing cranks only
i found the old distibutor teeth were worn and damaged so i thought that was the problem but turns out it still doesnt start so then in the mean time from cranking so much i killed the starter. so i replaced that too.
I am without a vehicle going on about a week.
cant figure out problem
I have spark i have fuel and i believe the timing is correct too. The fuel pressure stays high i left gauge on for a while.
Oh and this started on my week off !!!!
Old Jun 25, 2013 | 03:38 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
What exactly are your fuel pressure numbers? to start it needs to be 60+ psi. did you have the codes read?? if so what were they. Are you positive you have good spark?
Edit: Take a look through This Thread on the same issue, see if anything helps
Old Jun 25, 2013 | 09:12 AM
Fuel pressure is 55 psi and it held and didn't leak down.
Old Jul 11, 2013 | 01:11 AM
I replaced the fuel pump again and now I have 60 psi I also replaced crank sensor and still the blazer only cranks and doesn't start any ideas? Its been a little more than 3 weeks. I miss my truck
Old Jul 11, 2013 | 01:12 AM
I also bought a pcm off and eBay store that sells pcms and had it programmed to my vin
Old Jul 13, 2013 | 01:26 PM
Any help would really be appreciated!
Old Jul 14, 2013 | 07:11 AM
Tempest73's Avatar
Tempest73 is on a distinguished road
Have you removed any of the spark plugs to see if they are wet with fuel? I would suspect fuel regulator.
Old Jul 14, 2013 | 07:55 AM
chris015's Avatar
Spray some starting fluid in the throttle body (Make sure to hook hose back up so the Maf will function correctly. If it starts then dies you do have a fuel issue.
toolshed59
22
Jan 15, 2014 06:58 PM
chevylover5
Dec 24, 2013 08:31 AM
RolliE319
Apr 10, 2013 10:29 AM
armydad71
May 3, 2010 01:48 PM
fast400
Aug 31, 2007 05:07 PM
