96 cranks but wont start
Old Oct 3, 2011 | 02:50 PM
davem3261's Avatar
davem3261 is on a distinguished road
Default 96 cranks but wont start
I am trying to help my dad get his blazer going again. It will crank and sputter every once and awhile but won't start. I tried some starting fluid and it still wouldn't start. We changed the coil on Sunday and it cranked for longer than usual but it did start. Now dad is calling me a day later and it won't start again. I put it on my scanner. No trouble codes and it had 170rpm when cranking so the crank sensor is working. Is there anything else that would keep me from getting spark?
Old Oct 3, 2011 | 03:44 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Sounds to me like you need to do a feul pressure test if their is not at least 55 psi at key on this is defintly his problem. Had a simmuliar problem with one not to long ago
Old Oct 3, 2011 | 07:18 PM
xgiovannix12's Avatar
here is all the information you will need for the fuel pressure diagnosis
https://blazerforum.com/forum/tech-a...agnosis-23038/
Old Oct 4, 2011 | 06:29 AM
davem3261's Avatar
That was the first thing I did, 61psi. It has no spark
Old Oct 4, 2011 | 06:09 PM
Lrain88's Avatar
Lrain88 is on a distinguished road
no spark at the plugs or coil or both? if it's not at the plugs check the coil if none at the coil try a new coil pack and you might be in luck.
Old Oct 4, 2011 | 08:00 PM
Mike98Blazer's Avatar
coil pack, ign module, distributor pickup.....possibly/probably one of those three items. TEST TEST TEST.
chevyokie
Aug 21, 2011 04:38 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
josh05
Sep 22, 2008 12:21 PM
91Blazerblk
Sep 16, 2006 02:25 AM
