96 fuel pump in 99 Blazer
Old May 4, 2009 | 11:25 PM
slrpro02's Avatar
slrpro02 is on a distinguished road
Default 96 fuel pump in 99 Blazer
Will a fuel pump from a 96 work in a 99 Blazer? I put the engine from a 96 into a 99 Blazer. It runs good untill it warms up, then when you push the gas towards WOT it boggs down. I want to take the fuel pump from the 96 & put it in the 99.
Old May 5, 2009 | 07:16 AM
Every part number I look up is different between these two years.
Have you tested the fuel pressure to see if that is actually the source of your problem?
Old May 5, 2009 | 08:32 AM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
Fuel pumps might should be different. Check the code on the fuel pump, and see which one you have.
Old May 5, 2009 | 08:39 PM
slrpro02's Avatar
Well i bought a fuel pressure tester from harborfreight, spent the whole day working with it untill I found out the pressure tester was no good. Then went to sears & bought one. Worked great. The pressure was 58psi, but would go straight to zero in like 1 second. Does that mean the fuel pressure regulator is bad?? I dont have the fuel pipe shut-off adapter to do the other checks. Should I buy one (where)??
Old May 5, 2009 | 09:17 PM
You should be able to make one by adapting to the threaded connection on the end of the fuel filter.
Old May 5, 2009 | 09:48 PM
slrpro02's Avatar
Yes I will try to put one together tomorrow. Where could I get the parts to make one??
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
