96 tranny won't shift into park
Old Mar 20, 2010 | 05:22 PM
toolman243's Avatar
toolman243 is on a distinguished road
Default 96 tranny won't shift into park
I had to change the pan gasket on the tranny. no problem done in 30 minutes. put the cable bracket back on and adjusted the linkage. It worked for a shift or 2 then would not go to Park. No problem I just readjusted it. same thing. Everything is in free and works fine. The cable is attached on both ends. I can go under and push it into park easily. What on earth am I missing? Any help would be awesome.
Old Mar 20, 2010 | 05:42 PM
blazendizz's Avatar
blazendizz is on a distinguished road
MINE does the same thing but sometimes when i slam it into park it work but idk what it is either "scratches head"
Old Mar 21, 2010 | 02:30 PM
Is the adjustment holding? Have you tried taking it one click further than you have it now?
Old Mar 26, 2010 | 04:17 PM
toolman243's Avatar
yes, the adjustment is holding.....i thought perhaps it was slipping also....but unfortunatelty it is holding....I have evengone to the steering column to see if there is something wrong there.....and yes i tried moving it all through the adhustment range....excellent ideas though......idk
Last edited by toolman243; Mar 26, 2010 at 04:19 PM. Reason: forget second part of reply
Old Jun 2, 2010 | 10:46 PM
iapoolguy's Avatar
iapoolguy is on a distinguished road
same problem with mine
is it possible the cable bad?
could the body shift that much to make it not shift?
no park or L-1
can do it at the trans but not by the shifter
96 blazer 2dr columb shifter
Old Jun 3, 2010 | 04:58 PM
toolman243's Avatar
Default my issue is resolved
i tried everything....finally broke down and took it to a real mechanic. it was a cable.
Old Jun 4, 2010 | 05:29 PM
iapoolguy's Avatar
Default found it!!
I finally figured out my problem...the floor board on the cab had a factory small hole that allowed water in under the carpet and insulation and it rotted the cable houseing to where it finally broke the cable sheild.
I went to the junk yard and found one today for 35,00 bucks because they took it off.He said it would have been 10.00 if I did it ! I was in a suit and at lunch. Well im off to replace it now
chcknugget
May 26, 2014 09:20 PM
spartanbananas
Jul 17, 2011 08:50 AM
ffalan
Aug 1, 2010 10:49 AM
Hiddenfarce
May 25, 2009 11:21 AM
Chakoose
Mar 27, 2009 04:35 PM
