'96 won't start without help
Old Oct 5, 2010 | 06:02 PM
SadFace's Avatar
SadFace is on a distinguished road
Default '96 won't start without help
Hi guys, thanks for reading.
I have a 96 Blazer with the Vortec 6 in it. In the past 2 months or so, the car would only start without assistance when it was over 95 degrees or so outside. The hotter the day, the easier it was to start. By assistance, I mean starting fluid, and one time in a pinch, a little gas down the manifold (I know, I know. I was stranded.). Now that the weather has cooled off, it won't start at all without a little starting fluid.
I've replaced the spark plugs and fuel filter in the last week, and once it starts, it still runs like a champ, it just won't start on its own. I don't *think* it's the fuel pump, because it never bogs or cuts out under acceleration or up steep hills or anything.
Any suggestions?
Thanks for any help!
Old Oct 5, 2010 | 06:23 PM
rob1971's Avatar
rob1971 is on a distinguished road
it night be your coolent temp sensor
Old Oct 8, 2010 | 01:02 PM
SadFace's Avatar
gonna try that real quick, if i can find it. 3 different autozones i went to yesterday didn't have a haynes or chilton for my car. got the sensor though, thanks for the idea. never woulda considered it.
Old Oct 8, 2010 | 02:13 PM
Bllazzr's Avatar
Bllazzr is on a distinguished road
had the same thing happen to my 96 a while back. mine was the fuel pump. the engine needs a lot more psi at startup than when its running, i have stick shift so i could cycle the key in and out of the start position a few times with my foot off the clutch to build fuel pressure,then start up. but that stopped working after a while and i had to replace the fuel pump.
Old Oct 9, 2010 | 05:01 PM
rob1971's Avatar
di that help you.
Old Oct 10, 2010 | 11:54 PM
SadFace's Avatar
coolant temp sensor: it doesn't seem to have helped, no. thanks for the suggestion though, i wouldn't have thought about it otherwise.
i guess i need to test the fuel pressure now, don't know what else to do. about to break down and take it to a shop.
Old Oct 11, 2010 | 09:46 AM
A fuel pressure test would have been the first step, IMO...
Ghalian
Feb 24, 2013 07:13 PM
lukeawilliamson
15
Apr 4, 2012 05:26 PM
PayneSource
Nov 27, 2011 12:32 PM
MightyMouse22
Nov 11, 2011 12:18 PM
kearney99
Jul 27, 2011 10:24 PM
