96BlazerOKC
96BlazerOKC
I just bought a 1996 Blazer LT awd ,4.3 vortek , 4-speed column shift,when you first start it , it runs well then after 8 miles of driving you give it gas & nothing.So if you put it in park turn ignition off & re-start it,put in gear runs good again.Fuel pump pressures up,changed fuel filter ,alot of pressure there & at the fuel rail also,check engine light does not come on & autozone came up with no trouble codes.Can anyone help me with this matter?
Welcome to the forum from New York!
*The 'New Member Area' is not for asking technical questions. Moved to '2nd Gen Tech'*
sounds like you have a problem with the air getting to the engine. Have you cleaned/replaced your air filter yet?
Edit: have you checked the coolant level? Or maybe it could be your water pump?
