97 blazer #3 fuse blows
Old Jan 13, 2011 | 06:46 PM
lac8362's Avatar
lac8362 is on a distinguished road
Default 97 blazer #3 fuse blows
My #3 fuse keeps blowing when i turn on the headlight switch
1/17/11 short is on headlight switch, headlights will stay on, parking lights and dash lights are out 4wd drive switch out too but works before i turn on headlight switch then fuse blows ???
Old Jan 14, 2011 | 06:49 AM
marksoftball's Avatar
marksoftball is an unknown quantity at this point
See if this description of what is on Fuse #3 helps.
Mark K
Attached Thumbnails 97 blazer #3 fuse blows-fuse-3-description.gif   97 blazer #3 fuse blows-headlamp-switch.gif
Old Jan 17, 2011 | 10:06 PM
neex's Avatar
neex is on a distinguished road
Were there any additional gizmos or accessories added recently? If not, try replacing the headlight switch? Are you sure that's where the short is? Just because you blow the #3 fuse when you hit the light switch, doesn't point only to that circuit or switch necessarily. Try connecting a test light to the #3 circuit at the fuse panel and then pull/replace fuses one by one till the test light calms down/dims. When this happens, you have found the circuit that the #3 circuit has been shorted to. Then when you look at the schematics, it should be much easier to fix.
How did you make out with this so far?
A.
Old Jan 22, 2011 | 03:44 PM
lac8362's Avatar
Have schematics hard to follow backup lights work and so does the brake lights after the fuse blows high beam and low also work. maybe not the light switch .the park lights are out dash lights out number plate light out. ????
Old Jan 23, 2011 | 10:55 AM
hcii's Avatar
hcii is an unknown quantity at this point
I can't recall the number of the fuse, but check the park lamp fuse. This fuse also controls the BCM (Body Control Module) and if this fuse is blown, it will cause the headlamps to do all sorts of weird things, possibly overloading them and then causing THAT (Fuse 3) to blow.
Old Jan 25, 2011 | 12:17 AM
neex's Avatar
I don't think we ever established whether or not any aftermarket electronics were installed or behind-dash repairs were done? Has there been any modifications with reference to cutting, splicing, scotchlock connects, etc?
Thanks!
A.
Old Nov 2, 2011 | 08:19 AM
lac8362's Avatar
replaced plate light blown out all is fine now
Old Nov 3, 2011 | 08:42 AM
neex's Avatar
Glad it's sorted but it looks like the gremlin tool while to tie down as they sometimes do!
Take care!
A.
plumba
Jan 11, 2013 04:36 PM
ncpi
Oct 12, 2011 09:17 PM
LowLife
Dec 18, 2010 09:45 AM
DREWZBOY
Apr 8, 2010 11:50 PM
skybolt31
Nov 29, 2009 03:10 PM
