ECM fuse blows while in drive/ 94 S-10 4.3 4DR 4x4
Old Jan 8, 2010 | 10:31 PM
DREWZBOY's Avatar
DREWZBOY is on a distinguished road
Default ECMB fuse blows while in drive/ 94 S-10 4.3 4DR 4x4
My ECMB or fuel pump fuse will blow every time I'm in gear and accelerate quickly. But if I'm in park I can floor the pedal and the fuse won't blow. Only while I'm in drive. I just put in a new fuel pump and fuel fliter after this problem started.
Old Jan 9, 2010 | 07:14 AM
Sounds like you could have a wire being pinched by something when you accelerate hard.
Old Jan 9, 2010 | 08:40 AM
DREWZBOY's Avatar
But it only does this when the truck is in drive?
Old Jan 9, 2010 | 11:31 AM
DREWZBOY's Avatar
Default Correction it's the ECMB 15 amp
The problem that I'm having is the ECMB fuse blowing when I accelerate fast in gear. When it's in park or neutral I can rev the gas as much as I want with out it blowing.
Old Jan 9, 2010 | 12:42 PM
vortecjimmy's Avatar
vortecjimmy is on a distinguished road
i had this exact problem myself, a few different things led to it though.It started back when my tranny mount went out, it got to the point when i accelerated hard at all i would blow an instrument/gauges fuse.all my gauges zero;ed out even the speedo,it also effected the shifting i had to manually shift it or it would try to start out in d and create a horrible drag.After geting the tranny mount fixed i never lost that fuse again.but then the ecm 1 i think it was,(i believe theres 2)would blow when i shifted it into drive but usually not till i was warmed up 10-15 minutes.It could sit idle for hours np.my mechanic pulled his hair out trying to figure it out,he finially found the bad wire/s in the wiring harness i think he said where it passes through the fire wall not fare from the ecm.Replaced my wiring harness and i have no problems now.we had determined the movement from the bad tranny mount caused this problem but i have no idea really just glad its fixed lol
Old Jan 9, 2010 | 12:57 PM
DREWZBOY's Avatar
Default Key turns fuse blows
Thanks I will check that out, because now when I turn the key the fuse will blow right away. and this is with a 30 amp fuse in the ECMB
Old Apr 5, 2010 | 07:43 AM
Harold's Avatar
Harold is on a distinguished road
Hey! Did you ever get this thing figured out? I am having a VERY similar problem.
Old Apr 8, 2010 | 11:50 PM
hayeri1's Avatar
hayeri1 is on a distinguished road
Cool
Check the fuel pump test lead. It hangs out of the wiring harness up on the firewall near the tranny dipstick. Mine was hanging out so far it touched the tranny dipstick tube, shorted to ground, and blew the ECM-B fuse. I capped the wire off, and tied it up - no more blown ECM-B fuse.
michaelg793
Aug 27, 2012 09:09 PM
roddy
Jun 28, 2012 04:52 PM
ncpi
Oct 12, 2011 09:17 PM
xs2003
Jun 1, 2011 10:46 AM
SevereDevil
Jun 12, 2009 09:04 PM
