97 blazer 4.3 runs great at high revs, p0300 at idle only
Old Jun 24, 2013 | 01:00 PM
JohninVa's Avatar
JohninVa is on a distinguished road
Default 97 blazer 4.3 runs great at high revs, p0300 at idle only
Just put the engine back together after replacing a cracked head. Now I'm getting rough idle and misfire code p0300 only at idle, as well as the CEL flashing. If i raise the revs, the flashing stops. Also if I start the truck and keep the revs up, the CEL never comes on and seems to run smoothly. I have triple checked the crank to dist. timing and its dead on the marks. Any thoughts are appreciated. Thanks!
Old Jun 24, 2013 | 03:56 PM
JohninVa's Avatar
fuel pressure key on is about 55, and engine on it is at 60, and holds steady for a few min after shut off.
Old Jun 24, 2013 | 04:03 PM
JohninVa's Avatar
also tried carb cleaner at vacuum lines, no change in idle speed. it did smooth out some with carb cleaner into air cleaner tube.... Sorry for the multiple posts, but it won't save my edits ...
Old Oct 12, 2014 | 03:45 PM
2savageblazer's Avatar
2savageblazer is on a distinguished road
Default same issue
Im hunting down the same problem let me know it you find anything. I'll do the same.
Old Oct 12, 2014 | 06:23 PM
Leaky 4.3's Avatar
Leaky 4.3 is on a distinguished road
Stuck EGR valve?
Dirty/hanging up idle air control motor?
Those are about the only 2 vacuum leaks that spraying the vacuum lines won't help identify.
LukasP
Jan 16, 2015 03:24 PM
catz37
Aug 24, 2013 01:46 AM
ek72
Aug 22, 2011 09:42 AM
demian5
Mar 7, 2010 09:00 AM
