No Trailer Lights
Old Oct 9, 2014 | 11:27 AM
blazercain2004's Avatar
blazercain2004 is on a distinguished road
Default No Trailer Lights
hey guys im hoping someone can answer me, my 2004 blazer 4wd has towing package from factory far as i can tell, the trailer lights have no power (trailer works fine on other trucks) i checked fuses under the hood in the distribution box and trailer fuses are dead none blown is there a module or another relay or maybe a wire unhooked maybe even a bad fuse block, im just curious i know on other models from different makes you cant have a control module out causing this issus
Old Oct 12, 2014 | 06:42 PM
Leaky 4.3's Avatar
Leaky 4.3 is on a distinguished road
Possibly a bad connection on your truck's connector? A bad ground would keep all of the lights from working.
Old Oct 12, 2014 | 09:42 PM
Trailer light circuits have their own fuses in the underhood fuse panel, (5 of them). To test the fuses, the ignition must be in the RUN position, headlamp switch in the ON position, and the 4 way hazard switch in the ON position. With a test light or DVOM, test both terminals on the top of each fuse:
The trailer park/tail fuse should show constant battery voltage. Left turn signal and left stop lamp use the same fuse. It should show voltage alternating from zero to battery voltage. Right turn signal and right stop lamp use the same fuse. It should show voltage alternating from zero to battery voltage. The CHMSL, (chassis high mount stop lamp) has its own fuse and should show battery voltage only when the brake pedal is applied. The trailer brake should show battery voltage only when the brake pedal is applied.
Philipx
Dec 14, 2015 04:29 PM
bobbya55
Aug 9, 2009 06:49 PM
Boyer2011
Jul 29, 2009 02:02 PM
blazermayne87
Jul 13, 2009 02:15 AM
Kellen
Oct 10, 2007 06:48 AM
