97 Blazer: 4wd issue while on the highway
and is really fun to get to. Persistence and an open ended wrench will do the trick. Check to see if there's any fluid in the switch before replacing. Also, the ball on the end of the switch should depress easily and freely. When I replaced mine, the stocker no longer did this.
Diagram LINK
Is the best I can find at the moment without crawling under my truck and snapping a pic. I got to mine by lying underneath the driver's side, head by the LF tire. Reach up and around the transfer case. It will be on the top right if you're lying how I described. There are three vacuum lines attached to it.
Found the vacuum switch...
Replace it along with the actuator under the battery. 4x4 works as it should again.
On the vacuum switch I removed, the ball was stuck in. This must be such a common thing to go bad the vacuum switch was on the "HELP" rack at the auto store.
I also picked up a for sale sign while I was there!
chriscrm
Jan 4, 2013 01:19 PM
Davidhicks80
Jul 21, 2012 05:29 PM
simplyjessi
Jan 21, 2012 10:10 PM
