97 Blazer 4x4 ls 4 door
I have a blazer that wont start it fires and will idle for about 10 seconds and then dies. then it will do the same thing for about 4 to 5 tries and then nothin. I have changed all relays,plugs wires, fuel filter, fuel pressure regulator, crank shaft sensor, fuel pump runs fine not sure where to go from here.....most of the info i have gathered from here is that it may be the fuel pump.....any other ideas would be Great.....
Thanks
d1v3r 'aka' John
Thanks
d1v3r 'aka' John
The dying after 10 seconds is typical of a passlock shutdown on the '98+ trucks. I'm not sure if the '96-'97 have the same type of system, but this type of problem is typically caused by ignition system problems on the newer models.
But I would start with a fuel pressure test. Just saying that the 'pump runs fine' is no indication of whether it actually is putting out the proper pressure or not. The engine requires >55psi to run properly. If the pressure is dropping after the engine is started and dips below 55psi, then it could indicate a restricted fuel supply line or a weak pump.
Athlon2012
12-16-2014 11:35 PM
hlaverty06
03-23-2014 09:25 AM
Guardian1014
07-11-2012 03:31 PM
dropd4door
02-10-2006 02:34 PM
