97 blazer crank but no start
Old Dec 9, 2012 | 04:51 PM
thedude's Avatar
thedude is on a distinguished road
Default 97 blazer crank but no start
Hi guys, I was having the normal problem from my ignition switch.. I replaced the switch and everything else is working again except for there is no ses light and it just cranks with no start!
Old Dec 9, 2012 | 05:15 PM
spittybays
Guest
Posts: n/a
Some more backround would be great. Did it start before the change with just a bunch of funky problems or was it dead.
Old Dec 9, 2012 | 06:41 PM
thedude's Avatar
well it would stall out intermittently but it would start right back up! the other day it died and would not restart! I thought it was the fuel pump cause it was not priming! but then I noticed there was no radio, dummy lights on dash, and it wouldnt come out of park! so I started looking on here and found it was most likely to be the ignition switch.. I put the new switch in and everything is working properly except it will not start.. it cranks just fine and the only thing i can tell is the ses (check engine) light is not on when i turn the key forward!
Old Dec 9, 2012 | 07:46 PM
50lb_cat's Avatar
Old Dec 9, 2012 | 08:20 PM
thedude's Avatar
but there is no security light?
Old Dec 13, 2012 | 03:32 PM
thedude's Avatar
Angry
Still spinning my wheels here?
Old Dec 13, 2012 | 04:08 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Check your wires to the crank and cam position sensor.Also check and see if you got spark from the ignition coil.
Buddykitchen
Dec 10, 2016 06:37 PM
Jayson
Dec 18, 2014 01:21 AM
benjamin tate
Dec 20, 2011 05:28 AM
rogersblazer
17
May 16, 2011 08:26 AM
stschuyler25
Nov 21, 2010 09:34 AM
