'97 blazer fuel pump
Old Mar 15, 2008 | 04:02 PM
glessen's Avatar
glessen is an unknown quantity at this point
Default '97 blazer fuel pump
New here guys.
I have a 97 chevy blazer that I can not seem to get it running right. I have replaced the fuel pump but it still wont run. I was told I am not getting enought pressure to it or something like that. But I know its the pump that is bad. I have used after market ones and they will not start the truck. Can someone please help me here.
Gordon
Old Mar 15, 2008 | 04:20 PM
rriddle3's Avatar
Default RE: '97 blazer fuel pump
[sm=welcomesign.gif]to the Forum, Gordon. First suggestion, create a 'signature' for your posts containing the important info about your truck (see mine below as an example). Now to the problem - if you have not done so, do a pressure test of the fuel system by connecting a fuel pressure gauge to the schraeder valve on the inlet line at the top rear of the engine. Turn the key to 'on' and see if the reading is ~55-62 psi. Turn the key off and see if the pressure drops more than ~2-3 psi. If the first reading is lower than specified, you probably have a bad pump and if the second is too low, you may have a bad fuel pressure regulator. After these checks, please repost and we will go from there with further checks and/or repairs.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
