97 blazer no turn signals
Old Apr 6, 2010 | 09:09 PM
boostdprobe91's Avatar
boostdprobe91 is on a distinguished road
Default 97 blazer no turn signals
Okay, I'm having a problem where neither side turn signals work. I've changed both flashers with brand new ones. Still nothing. Now my question is do these turn signal switches go out often? Or what else could be my problem.
Old Apr 7, 2010 | 04:43 PM
step66's Avatar
Sounds like either a bad ground somewhere(unlikely since the factory harness is pretty good) or the dreaded turn/dim/wiper/cruise switch issue...
Old Apr 10, 2010 | 12:35 PM
vanaman's Avatar
vanaman is on a distinguished road
How about your 4 ways? Do they work? If not, it could be your 4 way hazard switch. Very easy to replace, I think there is a pictorial here somewhere, part # 15174447 at the dealer, under $10
Old Apr 10, 2010 | 01:48 PM
Luvthyblazer's Avatar
Luvthyblazer is on a distinguished road
Check you fuses driver side door fuse panel I’m sure you have but if not do so 1st
2nd in the back of your glove box you should see a cover remove to expose relays there's 3 relays in there.
There all the same type one is for your flashers and the others are left turn/right turn signal swap one with the other to see if its the relay.
I find it hard to believe left and right would go at same time but something to try.
Are your hazard flashers work at all?
Next time your at the bone yard pocket these there common to your vehicle just verify the # on the side.
SubbinBlazer
May 24, 2013 12:56 PM
94fireblazer
Dec 12, 2009 04:03 PM
spydee28
Sep 2, 2009 10:04 AM
Litman15
Apr 19, 2009 07:23 PM
mendez918
Mar 3, 2005 11:42 PM
