97 Blazer oil cooler bypass
Old Feb 14, 2015 | 04:30 PM
Damato's Avatar
Damato is on a distinguished road
Default 97 Blazer oil cooler bypass
Has anyone used the GM 14081300 adapter to mount oil filter back onto block in a 4.3. How does the oil bypass if the filter plugs? Thanks
Old Feb 14, 2015 | 06:19 PM
Worx's Avatar
Banned
Worx is on a distinguished road
I do this to all my 4.3s,if you change the filter when you should you dont have to worry about it plugging up.
Old Feb 14, 2015 | 06:25 PM
If you're going this route, you might want to replace the "pressure regulating valve" (GM calls it oil pump bypass valve). The valve is in plain sight when you remove the adapter. If/when the spring gets weak or breaks, oil pressure takes a dive. Cheap part, under $15 at the dealer. Here is a "typical" illustration of how the bypass system works:
LesMyer
Jun 15, 2015 10:29 AM
litterbox99
Jan 3, 2015 09:33 AM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
Duntov
Mar 29, 2008 10:16 PM
Jetfixer
Jul 11, 2006 05:02 AM
