97 Blazer Turn Signal Indicator lights stay on
Old Oct 12, 2009 | 03:03 PM
SL5417's Avatar
SL5417 is an unknown quantity at this point
Default 97 Blazer Turn Signal Indicator lights stay on
I just finished a front end conversion and both my turn signal indicators light up when I turn my headlights on. The dash lights blink when I use the turn signals and the exterior lights all work like they are intended. I have checked my ground wires on the radiator support and they seem to be tight. The turn signal dash lights are fine until I turn the headlights on then both indicators light up. I think is has to be a ground but does anyone have any ideas?
Thanks
Old Oct 19, 2009 | 03:14 PM
SL5417's Avatar
Red face Update
Well I found that if I run a new ground to each turn signal, the dash indicators don't light up any longer. I also found that after a couple miles you also have smoke from a bunch of wires burning under your dash. On a positive note, my gas mileage went up with the help of the tow truck! This is why I need a new hobby ha ha, still waiting to hear what the damage is going to cost me.
Old Oct 26, 2009 | 02:43 PM
SL5417's Avatar
Default All better now
Well I got my Blazer back, and it turns out that both front turn signal bulbs had filaments that were shorted together which caused my indicators on the dash to stay on. The turn signals were working though. The wiring that went up in smoke was an after market remote keyless entry that was tied into the light circuit. So if your dash lights stay on and your lights outside are still working, check your bulbs.
Old Jan 23, 2013 | 12:43 PM
evfeez25's Avatar
evfeez25 is on a distinguished road
one question did the turnsignal bulbs still work even though the filaments were shorted together and by turn signal bulbs do you mean the ones below the headlights or the side markers right beside the headlights
BLAZE1999
Aug 14, 2015 06:59 PM
Firekatt
Nov 28, 2014 03:59 PM
ta3ff
Oct 14, 2009 05:07 PM
rryker
Apr 25, 2006 04:14 PM
shaka1111
Feb 13, 2006 02:23 PM
