97 Blazer wont turn over
Old May 30, 2010 | 10:54 AM
XStrobeLX's Avatar
XStrobeLX is on a distinguished road
Exclamation 97 Blazer wont turn over
replaced ignition switch, starter, battery, and cleaned terminals/ grounds. at the tip of my nerves with this thing.
Old May 30, 2010 | 11:16 AM
84BlazerS10's Avatar
any active codes?
also make sure your wires to the starter are in good contact it kept my car from starting one time.
Old May 30, 2010 | 11:20 AM
XStrobeLX's Avatar
havent ran codes but the wires are nice and snug
Old May 31, 2010 | 07:45 PM
YOURCONNEXX's Avatar
YOURCONNEXX is on a distinguished road
if it cranks normally but just doesnt actually start and rev up its your fuel pump. try turning the key to the on postion and see if you hear the fuel pump load up (the on position is when u turn your key and are able to move the power windows/or when your daytime running lamps come on) i went thru this last year and i have a 97 too
just be careful when you take off the fuel tank. there is a pressure valve at the front of the tank
if you need me to post my experience changing out my fuel pump just let me know. ill be on here for a little while tryin to find out why my a/c only blows warm air
Old May 31, 2010 | 07:56 PM
rriddle3's Avatar
If it cranks, but won't run, try this:
Engine Cranks But Does Not Run
Old May 31, 2010 | 08:16 PM
XStrobeLX's Avatar
I know for a fact its not my fuel pump that was just replaced about 6 month ago and it absolutey will not crank turn over nothing
tonylee
Nov 20, 2014 01:32 PM
Backdraft
Sep 1, 2014 09:08 AM
gothicsatan187
Jan 27, 2014 08:37 PM
93preludeSi
Dec 31, 2010 06:46 AM
leebnc
Oct 16, 2010 02:26 AM
