97 front clip to a 2004
Old Nov 10, 2011 | 05:59 PM
step66's Avatar
Default 97 front clip to a 2004
Heres a good one-And i've already been through this with a 96 to 97 swap. Not sure Iwant to do this again... Found a 2000 red blazer with a hit front end: Grille,bumper,hood,both fenders all toast! But A low milage car! I have all the parts to make it a 97 again-should I do it? Will all parts swap over? Any input?
Old Nov 10, 2011 | 10:02 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
yep all parts will swap over if you swap out the core support.
Old Nov 14, 2011 | 10:47 AM
billbobagns's Avatar
billbobagns is on a distinguished road
I am interested in your experience with the clip. I need to do a motor job, but don't look forward to working around all the stuff that's in the way. Instead, I'm interested in pulling the clip to make it easier to get to motor mounts and stuff.
Can you give me some idea, either in text or photos, what is involved in pulling the clip?
Old Nov 14, 2011 | 11:04 AM
research is key
Here you go:
https://blazerforum.com/forum/paint-...uestion-37119/
if you dont have the wiring harness you need to buy a new one for the '97 lmc truck has them
Old Nov 14, 2011 | 04:39 PM
step66's Avatar
been a couple days since I been here...one concern of mine is the front turn signal harness-95-97 sigs are in the bumper-later models in the grille-not too much of a difference in length-but GM is stingy on wire!All else seems pretty strait.
Old Nov 14, 2011 | 08:58 PM
I don't need to swap a clip from one truck to another, I need to pull a clip so I can do a motor change then put the same clip back on. I (and many others I'm sure) would like to have some idea of;
What is involved in this process and how long it might take.
Is it best to pull fenders, core support and hood as one assy, or is it better to take it apart?
Leave the inner fenders with all the electronics, or pull them with the clip?
Can you post photos showing locations of bolts etc?
Is body panel alignment difficult when going back together?
Thanks in advance for your info.
Old Nov 15, 2011 | 07:09 AM
Worst case scenario is that you have to extend the harness for the bumper lights. That's really easy to do. Stagger your splices & use good 3M shrink wrapped butt connectors.
This thread was created to discuss a front end swap and you are effectively trying to hijack it... Please keep this question in your thread on the subject rather than twisting someones active thread off topic.
MTopper
Jul 12, 2011 12:19 AM
rcantoys
May 3, 2009 11:53 PM
op952dr
Apr 3, 2009 04:09 PM
djdrew010
May 12, 2008 01:02 AM
alangri
Apr 11, 2008 09:06 PM
