97 ignition replacement
Old Oct 10, 2010 | 07:04 PM
Are you talking about the ignition switch? That is different than the ignition lock cylinder...
Your '97 should be very similar to the how-to's posted for the 98+ in the Tech Article (DIY) section for your reading pleasure.
Old Oct 10, 2010 | 07:09 PM
robertr728's Avatar
robertr728 is on a distinguished road
This is very similar to the above attachment but has a couple of different pics to go with it.
Old Oct 10, 2010 | 07:20 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Yea I guess which ever the 97's had a known problem with, Thanks. What one works together with the shift inter lock solenoid?
Old Oct 10, 2010 | 08:37 PM
The ignition switch does power the circuit for the TURN B/U fuse (hot in run & start) which also powers the shift interlock solenoid.
Old Oct 10, 2010 | 08:41 PM
gmbwrenchn's Avatar
And where is the ignition switch exactly located thanks.
Old Oct 10, 2010 | 08:43 PM
Are you serious? Have you just ignored everything that all of us have provided for you in terms of instructions???
Brian5792
Oct 24, 2018 11:34 AM
blazwest
Dec 7, 2008 07:37 PM
skoot61
Feb 19, 2008 11:20 AM
01extreme
Jan 18, 2007 12:57 PM
