97 jimmy 4x4 4.3 vortec transmission trick?
What the fastest way to get those blocked bolts to the transmission there ridicules to get to?Ive got a transmission and engine to pull but I'm wanting to put the transmission in a same yr blazer but I sure dont want to pull the engine in the blazer to get it out Ive got the whole front end of the jimmy and still cant get to driver side top bolt Thanks for anything
chilton manual lists unbolting the body mount bolts an jacking up the body 2 or 3 inches on mine i took out the carpet an used a 2 inch hole saw to make it easy to get at for any future work a flex head ratcheting wrench from the top might work if you take the dist out
extreme
12-01-2010 06:08 PM
ldkronos
12-13-2007 03:54 PM
GMdesigner
06-22-2007 11:43 AM
