97 OverHall
Old May 5, 2009 | 01:06 AM
bquick0000's Avatar
bquick0000 is an unknown quantity at this point
Default 97 OverHall
I just picked up a 97 blazer in great shape 300 bucks. No rust on body or frame. Needs some motor work done. Just wondering If theres a good rebuild kit someone knows of. And the years I can swap out the motor for one with the same plugs and stuff. Thanks for the help
Old May 5, 2009 | 06:30 AM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
I'm in the same boat as you. Still a noob when it comes to the 4.3L. Hoping to learn alot still.
Old May 5, 2009 | 02:28 PM
As far as an all inclusive rebuild kit goes, Summit & Federal Mogul have a kit #205-6505M000 that has rings, rod/main bearings, all gaskets, and a new oil pump for $230 provided that all of your bores/journals are good at stock size and do not need to be cut.
Old May 5, 2009 | 02:53 PM
bandidolenny's Avatar
$300? nice... In my opinion, you can simply buy a rebuilt long block from a reputable engine builder easier and cheaper. A used engine from a wrecking yard even cheaper than that.
Old May 6, 2009 | 10:49 AM
I work at a auto parts store and I could spend $1400 on a rebuilt long block with a warrenty. I'm trying to do this on the cheap, so I'm in the hunt for a good junk yard motor.
Old May 6, 2009 | 04:01 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
Wink
From one Minnesota guy to another.....and the rest of you guys I guess
Check out this web site, it's the best when looking for used parts
www.car-parts.com
