cat convertor problems
Old May 4, 2009 | 08:54 PM
scottmac's Avatar
scottmac is an unknown quantity at this point
Default cat convertor problems
Good evening all, I have been having a problem with my cat. convertor, it is rattling really bad, so I bought a direct replacement, I had already got a idea what i was in for but I tried to unbolt it and the bolts are just breaking off (I did soak them first) so I figured that I could just cut them and use the bolts that I got ahead of time but it seems like the cat and the muffler are welded togthere? Has anybody ran into this problem? any soultions? It is a 1999 4 dr 4x4.
thanks
Scott
Old May 4, 2009 | 09:05 PM
bandidolenny's Avatar
Its hacksaw or sawzall time. Your gonna have to weld back together... if unable to do this yourself you may end up taking your truck and parts to a muffler shop.
Old May 5, 2009 | 05:52 AM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
Default Cat replace
On my (former) '96 most of the bolts snapped off as you describe, leaving the button head and spline shaft stuck in the flange. I used a mini cut off wheel to cut slots in each flange that were slightly wider than the bolt. Then drove the remaining part of the bolt out sideways with a punch. There was plenty enough meat of the flange remaining to hold the new bolts in place. I used standard bolts as replacements; not the button heads with flanged shafts that were factory.
The cutoff wheel was much smaller than a saws-all and I was able to work under the car without removing the exhaust -- but just barely enough space. And it cut off the nuts that were inaccessible to a long wrench. The cut off tool was >$20 and I already had compressed air and welding. But decided to re-bolt the flanges since there was plenty of metal to hold.
If a previous owner welded the flanges, you're likely in for a new muffler too unless you have a good torch. Old welds are nearly impossible to cut with a saw or wheel. Factory flanges weren't welded but do stick pretty good.
Good luck.
Old May 5, 2009 | 04:46 PM
oisinirish's Avatar
Good luck.
Just a quick insert? I know you can get special drill bits for drilling out welds is it possible to get something like for a reciprocating saw?
Old May 6, 2009 | 04:18 PM
mel@3881's Avatar
mel@3881 is on a distinguished road
I ran a two inch tap-con screw right up the middle / bottom of the converter body and it stopped the rattle. Don't know if it will last but I'm hoping to luck out.
LucasMI
Jan 13, 2012 08:48 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
