97 vac booster push back on brake pedal
Old Dec 20, 2012 | 07:53 AM
berniescout's Avatar
berniescout is an unknown quantity at this point
Default 97 vac booster push back on brake pedal
hi,
noticed when shuting off my 97 blazer there is a push back on the brake pedal. transmission in park. this happens after engine shuts down. when i first noticed it i also noticed the cruise control was on, i shut off the cruse control and the problem went away for a few days, now it is back. will check out the vac hoses today ( i hope). any thoughts ???
thanks ,
bernie
Old Jan 6, 2013 | 08:02 AM
so far I can find no problems to cause the symptom. When i do step on the brakes I hear swish sound, I think it has always been there though.
thanks,
bernie
Old Feb 15, 2013 | 09:03 AM
new brake booster solved the problem.
Old Feb 15, 2013 | 08:42 PM
4x4blazerguy's Avatar
Smile
Glad you got it fixed. Sorry I didn't see your post earlier.
Old Feb 23, 2013 | 02:39 PM
no problem, I don't look at this site as often as I should either. next problem is rear axle. replaced it 6 mos ago and I hear bearings (pinion) i think. won't know till i tear it apart (again)
on the brake booster I wish wish I had done more searching as to how to release the booster push rod from the pedal. pin would not budge so I took it to a garage. after the fact I found out that the brake stop light switch rotates out of the way to release the pin. so is life, win some, lose some.
thanks
bernie
Old Feb 24, 2013 | 11:18 PM
I would put it on jacks or a rack & pin point where the noise is coming from before tearing it down. How loud is it?
Old Mar 4, 2013 | 08:04 AM
thanks, that is next on the list. I'll try it first with tires on, if not go tires off.
bernie
Old Nov 12, 2016 | 06:49 PM
maryoka's Avatar
maryoka is on a distinguished road
I have a 2001 Blazer brought it to shop for rear axle seal leak. Was causing brakes to seize up with stuff leaking onto them. I then found out it was the pinion seal leaking so more money spent on that repair then they said it needs new bearings. I brought it back a few weeks later for bearing repair only to be told the whole back end of truck undercarriage needs replacing omg. I now went to guy that sold me this vehicle and he is fixing it for about half the price the shop would charge me. Has engine light issue too but I already had that estimate done is about another 100.00 repair before winter as is hard to fill the tank keeps shutting down. Good luck with your truck. I never heard about the brake booster is very loud when I start it makes strange sounds. They had found a defective seal someone had pounded on with hammer so they cleaned that off and replaced the seal at no charge least they could do I guess.
zach bjorge
Mar 17, 2011 06:49 PM
whistle
Nov 20, 2006 12:42 PM
consernedguy
Nov 6, 2006 11:19 PM
JCG1
Suspension Tech
Sep 19, 2006 02:07 PM
khalid_20879
Jan 3, 2006 01:00 PM
