97 vs. 98 Rims/tire size
might be a silly question, but here goes
So i found some rims with tires that a person is selling that were on a 97 blazer. Im just not 100% sure if the bolt pattern/spacing was the same for a 97 and a 98.
Also i currently have 235 70 R15 on my truck and the tires on the rims i want to purchase are 235 75 R15. Im pretty sure the truck can handle the extra tire but id rather be sure before i spend the money, any help/info would be greatly appreciated
-cheers
-cheers
X2 to Twip-But I have never seen a Blazer shod stock with 70 series rubber...for most apps the 75 series was standard. Virtually any 15 (or larger)sneaker will fit,many without modifcation,depends upon what you want to spend on wheels and what you plan to do with your unit. I recently saw a stock 99 with 245/70-16 with no modifications(or so was told)and they seemed to fit well.Do your homework...
Personally for stock suspension I think 255/70/15's look a lot better than 30x9.5's on factory rims. I like meaty (wider) tires, and the 30x9.5's are the same width as the factory 235's. Too skinny for my taste.
