98 4WD Blazer Right Front CV Shaft
Old Jul 19, 2014 | 06:19 PM
litterbox99's Avatar
litterbox99 is on a distinguished road
Default 98 4WD Blazer Right Front CV Shaft
I'm replacing my right front CV axle.
I just replaced both upper control arms
so I have some experience here.
As I see it, I need to remove the following;
Wheel, rotor, caliper, backing plate, hub bearing
and wires, clips and what not.
So now I'm down to the knuckle. Do I need to
pop both ball joint's or can I just do one and swing
the knuckle out of the way to pull the shaft out?
I'm told once I have clearance, I can just yank
out or tap the CV shaft past 'this clip' and remove.
I guess what I am uncertain about is where the inner
CV shaft mates with the 'tube' off the differential.
Old Jul 19, 2014 | 06:29 PM
newguy's Avatar
i just did mine and all you need to do now is upper ball joint, knuckle will swing out and with a little monkeying around you can get the axle out of it. Yuo`ll have to pry at the inner shaft to get it out of the tube. Be patient and go back and forth to each side. You`ll get it. I pulled on my axle shaft and pulled it apart trying to take it out
Old Jul 20, 2014 | 02:46 PM
Well that was easy, went smooth. I did end up removing
the lower ball joint (it was bolted on) I was worried about
nothing !
Old Jul 20, 2014 | 03:19 PM
newguy's Avatar
Nice, hope my info helped
aping
Feb 7, 2012 02:22 PM
haha29
Dec 28, 2010 07:41 PM
Tony H
Sep 7, 2010 07:45 AM
cwiththehad
Sep 5, 2007 01:14 PM
redpeppers
Apr 7, 2007 04:55 AM
